orlandoclippertim
- Joined
- Jun 2, 2011
- 106
I couldt find this in the secret files.
Got all my ignition stuff on new. (rde-17) Trying to get the points set a .020.
The base unit twists with the hold down screw and opens up the gap----
Tried holding it back with the cam screw-- doesn't quite work---
screw driver between the plate and the point base--- works somewhat---
The sealoc manual mentions having a wavy washer under the hold down screw--- I tried a wiz type lock washer---
I cant see how a wavy washer will help this problem any---
I was able to get both points between about .023 and .028..... not happy with that....
I wouldn't care so much about the plug gap but I suspect this is fairly sensitive ….
Yall MUST have a secret trick here
Can someone give me a hint ?
Tim
Tim
