I did quite a bit of work this spring and winter to my boat including putting on a new teleflex controller,changing out my bellows and a new gimbal bearing. I have had the boat out twice since then with no problems. After letting off the gas and coming to a stop to re arrange a cooler i went to go back in for the day and my boat would not go in to gear. Pushing forward and backward the engin revs up but wont go in forward or reverse. no clicking noise or anything. I figured my drive cable broke either from the controller or the outdrive but both were moving back and forth and i tried to pull the drive cable to the outdrive with pliers.. it moves but doesnt feel like it it doing anything. It is not broke because i cant pull it out other than the few inches it should move. Does anyone have an idea on where to start troubleshooting this problem?
Thank you for all the help in these forums. I have learned everything I know here. I dont post much because I can usually find my problem by doing a search.
I have a 92 mercruiser 4.3LX. It is Alpha One.. Not gen II
