Hi Everyone:
I am about to install a new Garmin GPSMap 520s sounder unit (with the new G2 Vision SD card-has anyone tried these yet and have an opinion?) and have a few basic questions. I have a 1991 Bayliner Trophy 2002.
1) Regarding wiring to the the fuse panel, it says to have a 3A fuse on the circuit. My fuse panel uses plug-in type (blade) fuses, and the available connections now have either 10A or 15A fuses, can I just replace one of those with a 3A plug-in fuse or must I install a in-line fuse just before the connection?
2) It is recommended to install the tranducer on the starboard side of the transom, how critical is that? My port side seems to have less wiring and would hopefully provide less interference.
3) Assuming that the starboard side is definitely the way to go, if I had my transducer wire say at least a foot away from the tach wire and other wires etc, would that be far enough away to avoid any interference?
4) The manual says the internal antenna will be able to receive signals through a windshield or thin canvas. My boat already came with a mounted external antenna, can I just use that instead to receive a better unobstructed signal? I know you can't use an old transducer with a new GPS so I just wanted to make sure I can use an older antenna with a new GPS. It is a BNC type connector.
5) Which is desirable for sealing screws in the transom? Marine-Tex or 3M 5200?
Thanks so much,
Mike
Nanoose Bay, BC, Canada
Thanks so much,
Mike
