GPS Unit constantly "Acquiring Satelites"
massimofinance
My GPS unit is not working- it constantly is acquiring the satellites but never finds them. It is a 6 year old unit. Do I need to update the software on it, or do I need to replace/move the antenna? Thanks.
Re: GPS Unit constantly "Acquiring Satelites"
Ayuh,.... Are ya gonna tell Us just what Gps unit ya got,..??
massimofinance
I knew you would ask that (lol). I will check this weekend
Splat
Have you moved a large distance from last time it has acquired satellites? It may simply need more time to acquire the tables and such from the satellites.
Go into your menu and see if you have a option to input your current location, or start from new location.
joelybob
Also if you have not used it in a long time it also takes a while to lock on to satellites.
jhebert
Ensign
The time for a GPS receiver to acquire a position fix varies. Modern GPS receivers often have their own energy storage device, a large capacitor, which retains information about the satellite constellation and the position of the receiver. If a GPS receiver does not have a sense of its approximate location, the current time, and the orbital position of the satellites, the time to initial position fix can be much longer. However, no modern receiver should take more than five minutes to acquire a position fix.
If your GPS receiver is not able to acquire a position fix after five minutes, the problem is not related to missing ephemeris data or being unaware of its present coarse position. There is more likely a malfunction in the GPS receiver or some interference in your location. To rule out interference, try another GPS receiver in that location.
