Gps versus locator.
cvtech1
I hear about a lot of Gps for finding locations on the water, but I want to know how to be found on the water if trouble develops. Is there a locator that I can hook up to my VHF marine emergency radio? Thanks.
Bifflefan
Re: Gps versus locator.
Google "EPIRB"
its a locator that can be automatic or manualy activated in case of an emergency. there are a ton of them so be ready to do some reading.
slasmith1
an epirb is a very expensive way to do what you want. I think what you are reffering to is a VHF radio with DSC. The radio connects to your gps and has a distress button you can push that will broadcast your position to any other dsc units within range to include the coast guard.
Boatist
I agree if your radio has a DSC button then you can hook up most GPS systems to the radio. Then get a MMSI number and your all set. When you hit the Red DSC buttom your radio will transmit your MMSI number and position to any station in range. It transmits on channel 70 on 1 watt.
The MMSI Number give then your name an boat information and the GPS provides your position.
http://www.boatus.com/mmsi/
Before your buy a GPS Or Radio check the specs to make sure they are compatable.
Their are several formats and they must match between the radio and the GPS to work.
EPIRB (Emergency Position Indicating Radio Beacpm) works with sattelites in orbit to indicate your position.
Their are also PLB (Personal Locator Beacon) that you can wear on your person and they cost from $300 to $400 that will also give your GPS position. Some float and even have a built in strob light.
cvtech1
Thanks so much everyone, this was helpful.
