'85 Wellcraft Nova XL / 5.7L Chevy / Alpha 1.<br /><br />Did head job last Nov (due to burnt valves on two cyls with low compression) then winterized. Took it out for first time in April to finish timing it (total advance timing is set at 32 deg at 3700 RPM.) and it runs like a champ. That is until I peg it at WOT then after a couple of minutes it gradually loses power. Temp rises from about 145 to 165 deg while at WOT. RPMs are steady at 4600 at speed of 46 mph. When power dropped (I watched it slow to about 38 mph), I pulled throttle back to about 3200 RPM. Engine stabilizes and runs fine. Temp returns to 145 deg. Then if I advance back to WOT get same symptoms. Runs OK for a minute or two then gradually loses power again. Did this test four times in a row with exact same results each time. Have changed screen filter in carb (old one looked fine) and water separator with no improvement. <br /><br />Is it possible that fuel stabilizer from winterization could be contributing to this problem? I also noticed over winter that the fuel expanded and dumped through the overflow down the side of the hull. <br /><br />What's a good way to check the fuel tank vent for blockage? I've seen that mentioned on couple other posts as a possible problem. It seems to vent fuel out, but maybe its not letting air in - if that makes any sense.<br /><br />Thanks in advance - Good Vibes
