Re: Grease for drive shaft spline?
Anti-seize is preferable but grease will do. If you need to buy anything, buy anti seize rather than grease. If you don't have anything but grease, use that. in either case put it on sparingly and rub it into the splines. Do not "goop" it up. Too much will put hydraulic pressure on the end of the shaft and pre-load it.
