The grease nipple on the throttle tower shaft is on the bottom of the shaft. It is the very end of the shaft! Underneath where the remote throttle linkage is connected. It just doesn't look like a grease fitting that you normally see. If you dont see the hole in the bottom then clean it out with a piece of wire.
