Grease on rims
MRS
Do I need to tighten axle nuts three rims look like this not sure what to do to stop this. Thanks for any replies.
bruceb58
More than likely just grease from the cap or that rubber stopper...definitely not the nuts. When was the last time you pulled the drums and inspected your brakes and bearings?
And holy crap..does that date code really say 1290?
dingbat
Change your rubber caps.
I get 2-3 years before they dry rot and start leaking
harringtondav
Bearing Buddies aren't too expensive, and worth any extra cost. Also get their 'condom' rubber caps. No grease stains.
Lou C
Just replace those rubber plugs, sometimes that happens to them, I haven't had that problem in 15+ years of using the same style hub but it can happen, keep spares of those caps on hand.
MRS
Dang it I did buy them last month and now I can't remember were I put them. Looks like I will order four more then I will probably find the others....
JimS123
I dunno know about caps. Looks like lack of maintenance to me. If I had a leak I would see it right away. That looks like months of dirt and not trying to figure out why.
MRS
Boat and trailer bought new 2019 only had one with grease on the rim I did clean off stayed off for one trip then next trip two others did the same thing I put the photos couple days after last trip. They look like old grease on the rim but where I live high desert wind blows hard and dirt here is like talcum powder stick to everything.
JimS123
In the past 3 years have you serviced the bearings? If so, how much grease did you add? I think it would be unlikely that an un-serviced unit would leak. Leaks usually are due to bad seals.
MRS
Coup
A couple little squares of grease about every third trip thanks for your input. If still leaking after changing rubber seals will check seals.
bruceb58
The EZ-lube system, which I call LAZ-lube, is no excuse for properly maintaining your bearings by pulling every year or every other year. Using the zerk to push grease through is not letting you inspect your bearings or brakes.
dingbat
What is the drop temperature of the grease you’re using?
I use a grease with a drop temp of 450-500F to minimize the amount of “free” grease in the hub at any given time
I would put good money on this is your problem.
You shouldn’t need to add grease between bearing flushes unless you have a bad seal.
JimS123
Coup
There's your answer. You blew out a seal, or you simply filled up the end of the axle with grease and now its leaking past the dust cap.
