I'm putting back together my Nissan NS40C outboard after installing new impeller. I have the factory service manual. The manual says to use "recommended engine oil" on the splines of the lower unit input shaft when reassembling.<br />I used wheel bearing grease instead,like I would on my motorcycle.Of course I read the manual afterwards.There was no evidence of grease on the splines when I removed the unit. Did I screw up? Also, when I removed the prop nut it was not tight. Prop was able to wiggle on the splined shaft. Can't find anything in the manual about torque specs for prop nut. And the manual states to use Nissan grease on the prop shaft splines when reasembling. I'm confused.
