Grease seal cross reference
Warlord
I have an older trailer from the 60's. I am sure the bearings have been replaced since then and also the grease seals. However the grease seals say ' National ' on them and the number 50352. I cannot find such thing, so how do I find a new seal that will fit correctly?
JAL51974
Re: Grease seal cross reference
I had a similar problem recently on an old trailer. I found a local bearing supplier by asking the Autozone clerk, just asked him who he knew locally who speciallized in bearings. That guy helped me find just the right seal and bearing.
Fingernip
Not likely a local place for you, but i have used http://www.cbrbearing.com/ to get odd bearings for vintage motorcycles and such. If you can see the stamped size on the bearings they can match it.
Warlord
Well thanks all of you for your responses. I went and checked out Napa and found one that should work perfectly. It will be nice not having to clean up the rims again!
