TimeZone
- Joined
- Apr 19, 2012
- 48
Pulled the gimbal bearing out today and decided to replace the grease seal as well.
Is there a trick to getting this thing out?
I tried the slide hammer but it just slips off the soft rubber. There is a notch at the bottom of the housing that seems to go right through to the back side of the seal. Is there a special hook that can be used to get in there and pull?
Searching the forum I found numerours threads on pulling the bearing but no mention of the seal. From what I've read it's not much more than a dust seal and most people don't change it. But I'm a stickler for detail and would preffer to swap it out. It is visibly worn near the top as well.
BTW - The knowledge available on this site is awesome. I'm making a bearing insertion tool at work this week based on the specs found in the "Must Have" sticky and I already made myself an alignment tool a couple weeks ago.
TIA - Ron
TIA - Ron
