grease seal
wags
Can someone tell me the part number for the grease seal behind the Gimbel bearing. I have a Volvo 4.3 glg with a sx-a drive. Also, I have a leaking trim pump, the leak is comming from lil white plastic tabs on the side of unit. I was told this is a non serviceable part. is there a fix or aftermarket replacement for this $700 part???
Don S
Re: grease seal
The seal is PN 3883257.
That trim pump plug is going to be Volvos next big problem. In the past month, we have had 2 boats with this problem come in. The last one was yesterday, and you are the third in the same amount of time.
There is no repair, and there is no aftermarket parts. It takes the whole pump. They could easily replace just the plastic housing, but it's not available as a seperate part.
Here is the thread from a couple of weeks ago with a picture of the plug in question.
http://forums.iboats.com/showthread.php?t=405087
