Grease Type
Eyeman
After greasing my spline coupler and changing the grease gun over to U-joint and gimbal bearing grease, I decided to use the remaining spline grease to do the wheel bearings. Is that acceptable grease for that application?
smokeonthewater
Re: Grease Type
as long as you aren't mixing incompatible ie silicone/petroleum based grease you should be ok.... I personally use blue marine grease for EVERYTHING
