Grease zerk wont take grease
markn88
ok im trying to lube my merc gen 1 strendrive and when i hook up the grease gun i am not able to put grease on. i give it 3 pump and the pressure pushes the grease gun nozzle of the zerk. i end up with a blob of grease over the zerk. what is the problem? full of grease possibly, ps i didnt grease it last year.
thanks for looking
sutor623
Re: Grease yerk wont take grease
thanks for looking
Dirt and crud often clog up the hole. I take a toothpick or ice pick and clean it out a little, and it should take grease fine. If that doesnt work, have someone move the joint around a bit while you are greasing. Sometimes this will help to create a vacuum.
markn88
well i poked the holes with a toothpick but i like the movement idea
rickryder
change the zirk fitting......
markn88
i went and bought some today before work as a last resort in case that was the problem, just wanted to make sure there wasnt a trick to it or if the drive had to be in a certain position
smokeonthewater
don't make a new zerk your last resort..... just toss the old one and install a new one..... 2 minutes and done.
markn88
Alright guys here's the solution. When putting grease gun to fitting make sure your adaptor is the right size for the zerk! Ahh felt like an idiot, (hand to face) lol . Well all lubed with new zerks.
sutor623
Hahaha, we all learn our lessons, sometimes more than once. :p
