There's a nylon bush in the top of the ram, the zerks don't go to it.
Corrosion builds up on the outside of the nylon bush which crushes it causing it to tighten onto the shaft.
Pull it apart & fix it or try drizzling a little tcw3 down either side for a while to prove a point.
