Monterey10
- Joined
- Apr 13, 2007
- 194
96 Mercruiser 5.7.
I don't seem to be getting grease flowing out of the gimbal bearing seals when trying to pump in grease. (?)
I pulled out the old gimbal bearing. I pumped new grease into the zirk fitting and it flowed out the hole on the bearing seat. I noticed the location of the grease hole on the new bearing. It seems to have a small passage to the side of the bearing. I lined up the new bearing and pounded it into place. I pumped some grease into the zirc fitting, but it doesn't seem to want to go in.
I'm pretty sure that I should be able to see grease to coming out the seal around the bearing shaft, but this is not happening. I actually see a bit of grease coming out from the outside edge of the bearing. (where it slides into the housing. I tried spinning the bearing.
Perhaps my grease is too thick (?) I'm putting in synthetic (red) high performance grease. It is thicker than the black grease I sometimes see.
Perhaps I'm not doing such a good job of aligning the bearing on the grease passage. The bearing seems to bottom out when I pound it in. How much deep does your bearing sit in the housing?
Thanks in advance.
Thanks in advance.
