Greasing Wheel Bearings
Roadrager50
I was wondering if I could use marine grease to lube my wheel bearings. I am in the process of rebuilding the brakes on my trailer,and since I use the grease on my outdrive, I was hoping I could use it on the bearings. That way I would only have to keep one kind of lube on board.
oldjeep
Re: Greasing Wheel Bearings
Use wheel bearing brease.
Why would you keep wheel bearing grease on board anyways? Pack them correctly and forget them for a year. The only thing that comes of continually pumping grease into the trailer bearings is blown seals.
Roadrager50
No always keep grease on board so I can lube the trunion bearings.
tpenfield
It is OK with me if you use marine grease. I use it for everything . . . wheel bearings, u-joints, gimbally bearing, engine coupler, surge brake whatzits, trailer coupler & ball thingy, trailer electrical connector, etc.
90stingray
Here we go... another oil, I mean grease, thread in the works. So here it is, I use the "green grease" on everything on the trailer, boat, and my truck. Haven't had any issues :)
Ayuh,.... Please see below,...
V
V
V
V
V
V
V
V
V
V
V
ricohman
I was wondering if this thread would explode into a giant grease debate.
Maybe later...:facepalm:
tpenfield
OK grab your grease guns . . . :D
Pony
Bingo! At the landing I usually am shocked how many people's trailers have grease caked on the inside of the wheel from being overfilled and blowing the rear seal out.
DC20
I even use it on my golf cart as it has been known to go in the water, it doesn't float though, I checked.
ricohman
I know of a few people who have also checked on that.:D
lncoop
Yes, give it time. My ultimate Trailers and Towing fantasy is a grease/surge brake/tow vehicle capacity battle royale!:p:eek:
marcoalza
I'm all greased up and nowhere to go :facepalm:
DBreskin
So what grease should I use on my surge brake actuator to make sure I get the greatest towing capacity? Will a slipperier/hydrophobic grease prevent excessive weight transfer to my tow hitch?
:p
oldjeep
:p
Bacon grease
1960 Starflite
I've no comment on the grease type.
However, I wouldn't OVER grease them. I was pulling my enclosed motor cycle trailer, with electric brakes, to Florida and the darn thing started jumping sideways at low speeds when I applied the brakes. Pulled drums/hubs, turned out there was grease on the shoes on one side, not good. I had to unplug the controller when traveling thru towns till I got it fixed.
lncoop
Well, if you leave now you should be able to make the Arkansas get together. I know your trailer is ready to rock because you recently fixed the brakes, although you might run out of gas on the bridge..........:eek:
marcoalza
My dad always said beware of men who hang around trailers.
Is the Arkansas meet just for trailers........
