Re: Great Stuff (foam filler)
It's a 15' Terry Bass (1978). It's an old boat that I bought second hand and runs good. It just needs a little repairing due to soft decking. I torn out the old decking and discovered that it had been repaired once before (about 2x4 ft. section). It's funny about the original foam that was manufactured with the boat. When I pulled the entire floor out I noticed if had water soaked into the foam. The foam looked like the great stuff foam. It's funny because when I would go fishing, I could notice the boat would lean to the side that has the old foam (kind of like water would soak into the foam and just sit there. It made the boat water heavy. The repaired side was higher while in the water. I'm going to repair using the 2part foam and had torn out the old foam from the decking area. Thanks for the feedback.
