Hi - have a 1995 Merc 15hp Long Shaft 2 stroke - have tested it in a tank, and runs well but quite smokey. After removal from tank, there was a grey/beige discharge from the prop/exhaust and also from the venting just above the cavitation plate - is this anything to be concerned about? Lower lube looked clean - yellow/gold colour, no obvious signs of milky discharge..
If its normal - anything I can do to reduce it? don't want this running into our lake..
PS - there was an oily residue left in the test tank (garbage can) at the water line - dark oily colour.
I also have a jpeg photo if that would help!
Thanks
S
Thanks
S
