ranger481vs
- Joined
- Aug 5, 2019
- 104
I have a couple of noises I'm hearing in the video below. The first screeching noise is the belt, which I will be replacing. Then, following that noise, I you can hear what I describe as a dry grinding sound. This appeared to be coming more from the the stern side of the engine compartment. I only hear it under power and trimming. I don't hear it at all if I'm just gently idling about. On a side note, I have a Captain's call on the boat, which doesn't work right now. I don't really care about that feature at the moment. I'm assuming it isn't related, but figured I would note that, just in case.
Any thoughts on where to start troubleshooting the 2nd noise?
Thank you!
Thank you!
