grommetitus
ironhead83
grommetitus
Hello Forum Members
I've learned a lot reading your forum the past couple weeks.Thanks!!! I wanted to post a problem I just ran into.I have a Evinrude '82 15 hp kicker that started having cooling problems. I replaced my water pump.No change.Looked at the thermostat.Didn't have one.To make a long story short it was the cooling tube grommets between the powerhead and exhaust housing. They were almost closed up ,cutting off my water flow.I am going to try to post a picture.Hope this helps someone out.
rickdb1boat
Re: grommetitus
Re: grommetitus
Good info! I'm sure others will benefit from it....
OBJ
Re: grommetitus
Re: grommetitus
This is really not an uncommon problem for the 9.9/15's.
It can occur over time or especially if the engine had overheated at one time.
But good info none the less.....Thanks!
I'm going to also delete the other duplicate posts.
