sea_goin_dude
- Joined
- Mar 15, 2011
- 55
Check the following to see if you may be close to or over the safe weight limits for your towing vehicle and trailer.
A gross vehicle weight rating (GVWR)[1] is the maximum allowable total weight of a road vehicle or trailer when loaded - i.e including the weight of the vehicle itself plus fuel, passengers, cargo, and trailer tongue weight.
The difference between gross weight and curb weight is the total passenger and cargo weight capacity of the vehicle. For example, a pickup truck with a curb weight of 4,500 pounds (2,041 kg) might have a cargo capacity of 2,000 pounds (907 kg), meaning it can have a gross weight of 6,500 pounds (2,948 kg) when fully loaded.
Most cars / trucks, have a placard (sticker) with this information. It is located typically either in the driver's side door or doorframe, owners manual, or also may be present on another sticker immediately under the hood near the radiator, although that sticker more typically contains information about the size of the motor, various fluid capacities, etc.
