Ground bolt through hull? Brass or bronze silicone
rost495
Have a disc that appears to be brass or bronze, its about 2 inches round. Had a brass looking screw that goes through transom to hold disc to underwater line on back of transom. Was used for ground(correctly???) I could not save the bolt and now need 1 bolt. Unfortunately I can't find one... so I have to order, but is there a difference-- I can find bronze silicon, but not brass. Or can I use SS- thats easy to find in the country.
Thanks, Jeff
rost495
Re: Ground bolt through hull? Brass or bronze silicone
Bump
Chris1956
Sounds like a grounding plate. I believe that they are made of silicon-bronze, which is what you should use for the bolt.
