Re: ground terminals inside distributor
Well, I don't know if a distributor would explode, but all marine components are designed explosion proof.
Remember: The distributor has a LOT of sparking going on inside it. There is a slight gap (less that the spark plug gap) between the rotor and each terminal and, of course, it takes a spark to jump that gap.
Now, if there is a fuel leak inside the engine, fumes can build-up under the cowling, penetrate the distributor and be ignited. SO, even if fumes DO get ignited inside the distributor, the flame arrestor screen will stop them from passing through to the main body of the engine.
