Getting ready to install my fish finder this afternoon and trying to be prepared by the time I go down to the marina to work. I've found the fuse panel under the dash. Fortunately it has two open fuses with new crimp on connectors already attached. So power is easy enough. Getting a little confused about the ground wire though. Figured the fuse panel would also be grounded...and also assumed the wires would be black. But I've seen no black wires running from the fuse panel. <br /><br />Any tips on finding the ground wire? Dumb question, but will the ground wires be hot if I test them with a voltmeter? Worse comes to worse I'll trace the ground from the stereo but its on the other side of the boat....or I'll pull the electrical diagrams and trace a ground wire from a gauge or something.<br /><br />Any tips would be great. Thanks!
