I am going to run 3 ground wires for my boat trailer. One ground wire for each light and a frame ground. When I splice the 3 wires to the wiring harness ground should I use heat shrink tape ? Can I just splice them together and tap the connection? What is the best way to hook the ground wires together
There is a short ground wire on the wiring harness I am NOT going to connect it to the front of the trailer , I was planning on hooking the 4 wires together and then hook the frame ground wire to the back of the trailer. Is this a good idea to hook the ground wire to the back of the trailer?
