renegade15
- Joined
- Mar 29, 2009
- 99
Well, atleast I think it's a grounding/starter issue! Just had the motor rebuilt and have been out a few times so I was hoping it was just a cable that came loose from re-assembly, but does not appear it is so. The motor cranks over really slow. Batteries both fairly new and fully charged, 12.6 and 12.64 volts. To single out the batt switch I bypassed it and connected one battery straight to motor start pos and neg. Still cranked slow. I thought maybe starter was going bad and decided to try to tap it with a rubber mallet while the motor was cranked, to my surprise sparks started emitting from around the starter shaft and the starter gear teeth were sparking/arcing on the flywheel, I also noticed at this time that the negative terminal stud on the motor was HOT and the neg term on the battery was fairly warm. At my friends suggestion I removed the starter and cleaned where it mounts to the engine block since that is how it gounds, reinstalled, and it started right up. Went ahead and took it out on the water and ran all over for a day, seemed to be it?!?!
Well now it is back to a slow crank. So tonight I decided to bypass the main batt cables to the motor thinking maybe they are bad and used two of the jumpers from the dual batt setup to go from one of the batteries to the motor. Still a slow crank and sparks from bendix gear to flywheel and out from around the starter shaft and hot neg stud on the engine block...
So I guess the main question I have, is the starter bad, is there some other grounding issue going on????
