Hello folks.... How do I go about grounding the ground wires on my aluminum boat. Do I just bolt them to the hull or the ground on the battery?
Also I started having probelms with my key ignition switch and at the same time the boat began to miss at 1/3 throttle but at WOT it seems to work fine... I changed the switich and it still misses a bit.
Thanks
Thanks
