Getting_started
- Joined
- Nov 14, 2008
- 21
I wired up running lights on a friends boat last week and did a quick hookup for testing. I just ran a hot and ground wire from the battery to the lights and he went out night fishing to test things out. An hour after turning the lights on, his motor died while trolling. It's in the shop now getting looked at. There appears to be a spark, but maybe not strong enough and the shop says a fuse was blown and possible problem with the stator.
I would normally have run the ground from the lights to the boat itself rather than back to the battery. Do you think this caused the electrical problem with the motor ?
