Growling noise only on hard left turn and stiff shift cable
Status
Not open for further replies.
stl1kmd
OK....I have a 1988 Four Winns Horizon. 5.7 liter V8. OMC Cobra. We had a very hard winter this year and it played hell on my boat. I winterized it the same as I do every year, however, somehow the engine block cracked. I had the long block replaced by a certified OMC mechanic and the engine is now running fine.
After the replacement, I hooked the boat up to the flushers and I got gear lube running out. I took it back in and they pressure and vacuum tested it and replaced gaskets on the gearcase. So far, I havent had issues with water in the gearcase now. However, when I took it out for the first time:
1. The shift cable is alot stiffer than it used to be.
2. I get a growling noise only on an end range left turn. It does not do it turning to the right. After discussing with the mechanic, he stated that it is not the Gimbal Bearing or the u joints because he checked those when he had the out drive apart replacing the gaskets. He also stated that its not the alignment. What else could it be? Any input would be appreciated. I am out of ideas.
stl1kmd
Re: Growling noise only on hard left turn and stiff shift cable
Well, I dropped it back off at the mechanic. He said he is going to put it on the water in the morning to dig into the issue. I am still stumped as the u joints and the gimbal bearing is good. Why would it only make a growl on a hard left turn and not a right turn?
reimelss
any word on this?
My boat makes a noise when i turn as well..my ujoint is also good and my GB looks good..its not loose/doesnt have any play and rotates if i turn it.
let me know.
thanks
any word on this?
Ayuh,... It was almost a Year ago...
Gimbel bearings have to "Feel Smooth"....
U-joints need to be disassembled to be inspected...
Status
