Grumman Info
mls2002
I own a 1995 Grumman 1666sp aluminum V hull.<br />Since the OMC selloff I am unable to find out the hull& gunule thickness along with other info you might find in a sales brochure. Any info or comments (good or bad)pertaining to this boat are welcome.
12Footer
Re: Grumman Info
They are built like Grumman Hellcats (no pun intended). The name is synonemous with aluminum craftsmanship.<br />You can try the yahho.com ,and search under it's name. I do recall seeing a grumman/Lonestar boater's club, but can't find the link. (just tried).<br />But you may be able to locate it thru Yahoo (didn't try that one yet).
singerjr
Re: Grumman Info
mis,<br /><br />Click here for current mfg. and history of Grumman boats. This Co. is still making the 16 footer. A lot of info here.<br /> http://www.marathonboat.com/history2.htm <br /><br /><br />Click here for a 1995 boat just like yours that is for sale. It will give you an idea of what others value the boat.<br /> http://www.hiawathaboat.com/erlander.htm <br /><br /><br />Hope it helps!<br /><br />Good luck and welcome to the best boat site on the web! ;)
SeaDawg
Re: Grumman Info
Grummans are very popular in Delaware, you will see many on the water.<br /><br />I would not hesitate to buy one, if it fit the bill for what I was after.<br /><br />Bombadier will still honor the hull warrenty, if the boat still has it.<br /><br />I owned a Sea Nymph that they replaced with a Lowe, because of a corrosion problem.<br /><br />Can't say enough good things about Lowe for their replacement support on a 7 year old boat.<br /><br />I'd expect Grumman owners would get the same treatment.
