gt150 no spark
I don't understand why disconnecting the kill switch at the pack didn't give me spark but disconnecting the master big red plug gave me spark?? This is a ignition key or tether safety switch issue tho correct?
Well I unplugged the plug to the pack and there are other wires in the same plug as the kill wires that's probably why? I would have had to cut the wires and didn't want to do that.
Another thing to add. I did cut the black yellow wire from the control to the main red plug. Why didn't that give me spark? The 2 black yellow wires going to the pack run from that one so it should have been the same as unplugging the red plug right?
Never mind got it running. Took control apart took everything apart checked it looked good put it back together and it started.
