guage johnson 2000
josip77
hi
is true when discconet VRO pump oil lampe must turn off? on my guage oil lamp(not low oil level) works on when i disconnect VRO,i try on desk and oil lamp stil works on,what color is wire from VRO to guage?
bestregrds
marinemech1
Re: guage johnson 2000
hi: I think by your post you are coverting motor from injected to a mixed engine?
assuming this is the case you must disconnect oil supply hose and plug the oil in fitting
disconnect the 4 wire (black,brown,gray and purple) from the backside of the oms(vro they haven't used vro since 1996) pump and of course run 50:1 fuel/oil in your motor
josip77
hi
no,problem is ,oil lamp works on all time,i dont know is problem in guage or in VRO,VRO works ok,oil is in gasoline,when i discconect VRO 4-wire waring lamp stil light on???
thx
Chris1956
Josip, If you have the "System Check" Gauge, you have lights for low oil level in tank, overheat, restricted fuel(check engine) and no oil at VRO pump. Wiring for that motor is not easy. It is best if you get a service manual to trouble shoot.
