Guest battery charger 2623
Prop Daddy
Hello All,
Need help with the charger above. It's a 3 bank charger and about 5yrs. On the boat I have a 24V trolling 12V system for cranking and etc... Any help on how to wire the batteries to charger. No manual of course. outputs #1 24V 10A #2 12V 5A #3 12V 10A.
Thanks
dockwrecker
Re: Guest battery charger 2623
How many batteries are you carrying? Your charger can accommodate 4. The first two should be in series ie pos to negative/negative pos= 24v. for the trolling motor. Your charger should have separate leads for these. Your cabling should tie the positive to the negative of both 12v batts to give the 24v for your trolling motor. The charger should be connected to the + and - for this system. For the rest, the 12v should go to the + terminals and a common ground can be used between the other batts if you have them. (two additional batts) Hope this helps.
Shife
Guest has excellent customer service and tech assistance. Send them an email with your query and you will get detailed instructions.
Silvertip
If you have a mulitbank charger each pair of outputs (+ and -) are totally isolated from each other an as such each output pair can be connected directly to any battery whether they are in series or parallel.
Prop Daddy
Thanks for the info. I am running 3 batteries 1-12v for cranking 2-12v in series for trolling.
