Hey guys,
Hoping you can help me with this, I have a 2010 Tahoe Q7i SSI with a Mercruiser 5.0 MPI 260HP with an Alpha Drive. I picked up 2 test props on the shops recommendations - see below; performance increased. The shop suggested I go down 1 more inch of pitch. Wanted to get some options if this is the correct course of action, also should this boat need a 16P prop?
I did have the boat serviced and the engine checked out fine. Compression, fuel pressure, etc...
According to other sources this boat should run around 52mpg.
Prop 1 (Original prop) Diameter 14 - 1/4", Pitch 21 3 Blade (Model832832A45 21P) - Aluminum
41 MPH (GPS) at WOT with 3900 RPM
Prop 2 (Test prop) Diameter 14 - 3/4", Pitch 18 3 Blade -SS
47 MPH (GPS) at WOT with 4500 RPM
Better hole shot.
Prop 3 (Test prop) Diameter 14 - 1/4", Pitch 14 4 Blade -SS
46 MPH (GPS) at WOT with 4600 RPM
Great hole shot.
1) Performance issue you are trying to correct.
All around bad performance. Slow to plane and low top end.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Mercury Marine, 832832A45 21P, Aluminum
3) Current prop diameter and pitch (required).
Diameter 14 - 1/4", Pitch 21 (Model832832A45 21P)
4) Wide open throttle RPM and speed with an average load (very helpful)
3900 RPM, 41MPH
5) Engine/drive make, model, year, and HP
Mercruiser 5.0 MPI, Mercruiser Alpha 1, 2010, 260HP, Drive Ratio 1:47
6) Boat make model, year, length and weight
2010 Q7I SSI, Length 20'6" Beam 96" 45Gal Fuel Tank, Dry Weight 3031 lbs.
Better hole shot.
Great hole shot.
3900 RPM, 41MPH
