gummed up carbs
smsscuba
Hi,
What is the best way to clean your carbs if they have varnished over inside?
Cheers
Shaun
Fareham UK
crem1
Re: gummed up carbs
Solvents, such as paint thinner, or go to Home Depot and get some paint brush cleaner.
turbinedoctor
Re: gummed up carbs
Check to see if your auto parts store carries a gallon can of GUNK carberatur cleaner or some other brand. I see you are in the UK so I don't know if they are as strict about VOC's as we are here. The old stuff worked muck better then this new environment friendly version. Completely disassemble your carb and soak in the solvent for an hour or two then blow through all ports with compressed air or the aerosol can of carb cleaner.
Durwood
