Had clicking, now no clicking :(
85Playliner
Hi all and I thank you in advance for your responses.
85 Mercury Outboard - 50HP. Bought this boat and it would start with the ignition switch and once I recieved it it would click however it would not turn over to start to no clicking at all at the Solenoid. I can jump the motor at Solenoid and engine runs fine but I get nothing when turning at the ignition switch. I have replaced the ignition switch and still no clicking at Solenoid while I have checked all wiring connections with a multimeter and I have 12V at both the ignition and Solenoid small terminals.
HELP PLEASE?!?!
Thanks!!!
WillyBWright
Re: Had clicking, now no clicking :(
Uh, replace the solenoid? I replace a lot of them every year. They wear out. ;)
(Out of the frying pan, into the fire. Welcome to iboats. :))
85Playliner
Thanks Willy for your response. Replace even if I am getting voltage to it at both large and small terminals?
studlymandingo
Yes, if you are getting voltage at the terminals, but no start, then the magnetic switch is not engaging.​
85Playliner
Thanks Studly, I assume that the magnetic switch is inside of the solenoid? Sorry I am VERY new to this and I appreciate greatly your help!;)
studlymandingo
Time for a new one.
Time for a new one.
It's inside, non-repairable, just put in a new one; it's a simple procedure.
85Playliner
Thanks again Studly, it's on order. It's amazing how much I have learned in the past two weeks.
jebeebe
the magnet pulls down a bronze washer that completesthe circuit from one big post to the other big post to the starter. These contacts get green gunk on them from arcing and just quit.
