Hailing Schematic!
D
DJ
Guest
Schematic,<br /><br />Working on an old Minn Kota trolling motor-model 599. The switch that controls 12/24 volt is bad. The switch has three leads.<br /><br />Do you know how this switch would be wired internally? When I look at replacement switches, the only three lead switches are DPDT (on-off-on).<br /><br />I'm not sure a on-off-on switch will work in this application. :confused: <br /><br />Ideas?
petryshyn
Re: Hailing Schematic!
Hi Dj<br /><br />This is probably what you had......<br /><br />
<br /><br /><br />This is what you can do with a DPDT center off.....<br /><br />
<br /><br />Good luck! :)
D
DJ
Guest
Schematic,<br /><br />Comprende! Muchos gracias senor. :D
Hooty
....not sure if it's am or fm but there good.<br /><br />c/6Hooty
