The transom on my 17 I/O is rotted due to a loose thru bolt on the drive mount. It is soft in an area about 6 in diameter. Now for my hair-brained idea
.I was thinking of drilling the thru bolt down the center and cap it off with a zerk fitting and then cross-drilling perpendicular holes on the sides of the bolt. I would then assemble the bolt back onto the boat, fill a grease gun with epoxy and with up to 1000 PSI inject the epoxy into the rotted area.<br />My question, would this work? This is an old boat that I dont want to put a lot of $$$$ or time. The grease gun will be a cheap hand operated type so I can control the pressure and rate
My concern is, will I force epoxy where I dont want it to go? I dont care about what leaks to the outside but I dont want to fill the gimble area.
