Re: Half ton for a 26ft boat.
Ayuh,.... Somewhere 'round the driver's door frame is the GVW sticker,....
I'm bettin' yer Over-weight, or so close it'll be a White-Knuckle ride.
The Gross Vehicle Weight rating on the door sticker is not the amount of weight a vehicle can tow.
(GVW) Gross Vehicle Weight is the total weight of vehicle, cargo and passengers.
(GVWR) Gross Vehicle Weight Rating is the maximum allowable weight of the fully loaded vehicle.
(GCW) Gross Combination Weight is the weight of the loaded vehicle (GVW) plus the weight of the fully loaded trailer.
(GCWR) Gross Combination Weight Rating is the maximum allowable weight of the towing vehicle and the loaded trailer including all cargo and passengers.
Maximum Loaded Trailer Weight. Set by manufacturer depending on engine size, gear ratio, body style, 2x4/4x4 or wheel base.
In addition to those you also have front and rear (GAWR) Gross Axle Weight Ratings and tire weight ratings to figure in.
As an example my 2002 F250 Supercab 4x4 3.73 gears, 6 speed manual transmission 7.3 powerstroke.
GVW 7200# the last time I was on a scale.
GVWR 8800#
GCW Varies depending on which trailer I tow.
GCWR 20,000#
Max loaded trailer weight 12,500#
Now the scary part. I can tow a 12,500# trailer and I'm not required to have brakes on it in Missouri.
