Handheld depth finder
Silvertip
Re: Handheld depth finder
And when would you use this? Be aware that if you are running 30 MPH you are not going to stick this thing over the side to see how deep the water is. Even if you did, it reads depth at that point in time. By the time you got a reading your prop would already be history. You really need something that can map the bottom so you can follow the contour and tell ahead of time whether you risk grounding. Even the cheapest fish finders do this nicely. I've used a similar item and found it to be useless except for ice fishing when trying to locate a hump that I knew was in a general area.
