Re: hard cold start
.....i still have hard time to turn it on. i keep trying the engine starts but trembling until the chock start warming up ......
...Okay, let me try.
Next time you prepare to start with a cold engine (and before you even put the key in the switch):
Open the doghouse and remove the flame arrestor.
Have an assistant pump the throttle at least twice in neutral while you observe the carb. You are looking for two things that should happen in the blink of an eye: (1) fuel squirting from the accelerator nozzles into the carb's throat and (2) the choke butterfly snapping CLOSED.
If either or both actions do not happen the engine will be next to impossible to start from cold (but would more than likely re-fire if the engine was warm).
And, be advised, the longer you leave the key in the run position during starting attempts, the weaker the choking action will be.
