Hard right turn when I let go of wheel
RICK8370HP
For some reason when I let go of the steering wheel my boat wants to bank to the right.<br />I think I set the shaft of my motor right but could someone possibly verify this with me.<br /><br />thanks Much!
angus63
Re: Hard right turn when I let go of wheel
Adjust trim tab on motor to the right until balanced.
Brew2
Just in case your not sure....the trim tab is just above/behind the prop on the underside of the cavitation plate.<br /><br />Good luck!
RICK8370HP
Thanks you guys I'll give it a shot and let you know.
Scuda11
Is that an easy adjustment, cause I have a similar problem.<br /><br />Thanks
angus63
Loosen bolt,move tab 1 or 2 degrees in the direction of the pull, tighten bolt, and test ride. Repeat if necessary.
