roozterdvx
- Joined
- May 29, 2006
- 57
'98 Mariner 225EFI
This thing has had a hard shifting effort since I got it and I've been trying to track this down. I figured the pivot bushing under the powerhead might be bound up with crud/salt/etc. so i've been spraying the s**t out of it with penetrating oil after every trip, during storage, and before every trip.
By the way, I disconnected the cables at the motor and the controls move easily so I eliminated the possibility of cables or helm control.
Spraying the pivot seems to have helped, the shifting got a little easier but still not perfect.
I went out this past weekend and the shifting effort is the same but now I'm getting some grinding before it engages forward gear. Reverse seems to be about the same as before, just a little grind, 1 sec maybe, then it engages. Forward grinds for what seems like forever unless I advance the throttle a little, then is slams into gear. I know this can't be good for my L/U.
I'm thinking that when I disconnected the cables to check for ease of movement, the shift cable may have come out of adjustment. When I was moving the controls I felt a slight hang-up and looked back, the threaded adjuster was getting caught as the cable was moving.
Does anyone know the correct proceedure for adjustment?
I'm also getting ready to drop the L/U to change the water pump. When I do, I'll disconnect the cable again to see if the shift shaft moves freely with no gear case attached.
(I don't know what's worse, if it's tight and I have to remove the powerhead to fix it, or if it moves easily and i have to dissassemble my L/U to fix it.)
