Oldsaltydog
- Joined
- Jan 27, 2004
- 322
I had to drop the lower unit in order to replace the seals. According to instructions, I put the shifter into forward gear beforehand, but it required quite a push. (I keep reading not to shift a non-running motor, but how can that be done, especially with remote controls?) In any case, now that I have the lower unit back in its place, the gear shifting is much harder than it used to be. What could the problem be, like a bent shifting rod? Any advice, please? (While I am at it, how can a person tell what gear the seperated lower unit is in and can it be then manually shifted if necessary? How can a person make certain that the remote gear shift and the lower unit are properly matched/adjusted?)Please help.
