billybuck1
- Joined
- Aug 8, 2010
- 10
I pulled out my 15hp this spring. Started up and ran great for the day. A week later, wouldn't start. Pulled and cleaned carb. Got it started, would not reach high rpm as though on one cylinder. Did carburetor rebuild. Still hard starting and no top end. Gave to mechanic. Did compression check; good compression. Needed power pack. Achieved high end after power pack. Would not run without his pumping fuel line bulb at high speed, and smoking alot. Brought it home. Replaced both fuel lines under cowl, installed new fuel pump, runs great now once started but have to use starter fluid to get started, and if it sits for several hours, need starter fluid again, then runs beautifully once started. Thoughts on why I need the starter fluid??
