I own a 1987 Merc 115hp I6. The problem is it is a bugger to start when it is cold or been setting for a say hoir or so. The carbs have been rebuilt to specs have done comp check they are in specs and have also done leakdown tests and as well they are in specs. RunningL78vplugs and they are all the same color. once engine fires it runs excellant. I beleive the mixture jets are set at 2 turns out from being slightly seated. The best way to get this motor to fire up and run is to trim it all the way under and choke and crank like crazy. HELPPPPP I know I have missed something or havent done something right. If anyone can help me that wuld be greatly appreciated.<br /> 1FASTLASER
