07 Chaparral 254 Sunesta.
My random hard start continues, even after replacing the IAC with a brand new OE unit. In fact, it may be a tad worse.
I have to crank the starter a few seconds to get the engine to fully fire. If I release the key early, on the next turn the engine will crank and crank and intermittently fire a cylinder or two but not stay running. I then have to push the neutral button and crack the throttle to get it to fully fire.
Recently put in new plugs, fuel filter parts, neither improved the situation. Runs 100% smooth otherwise, runs 50mph on GPS. Being going on for last 30 hrs or so, 197hrs on it now. Can happen when cold or hot.
Throttle body issue? Vac leak somewhere?
Thanks.
Thanks.
