CrestII
- Joined
- Aug 18, 2009
- 37
First time posting been reading for the last couple of years. I have a force 96 75 hp outboard that is very hard starting and when it finally does it will only run at wot. When i try to bring it back to idle it dies instantly unless i open it wide open again.This started last year on the lake while we were camping. I replaced the fuel primer valve as it went bad last year.I have changed the fuel line,primer bulb,fuel pump kit installed,new plugs, new inline fuel filter,and took carb off and cleaned and blew out with air. Nothing really came out of the carb when i cleaned it.Put it back together and still same problem. I checked the compression on top two cylinders and they were ok ,cant get to the bottom one cause where it sets so low i need the attachment to reach it but the plug looks the same as the other two (oily).Any help would be appreciated it hasnt seen the water all summer.
